viper fat boy vs specialized hardrock
Je voudrais avoir un avis sur un velo car je vais bientot changer le mien (dkt 5.3)
J'ai trouvé deux velo qui me plaisent bien et donc je voudrais un avis sur le quelle est le mieux
Le viper Fatboy: dans les 430€ sur chain reaction sinon 699€
Description:
• Cadre: alu 7005 avec logo viper incrusté. Top tube hydroformé. Bases surdimensionnées
• Tailles: Standard
• Couleur: Matt Grey
• Fourche: Suntour “XCR-D”
• Débattement: 120mm
• Freins: Hayes Stroker Ryde V.8 Hydraulic disc (203mm)
• Pédalier: Shimano 175mm 42/32/22
• Dér avant: Shimano Alivio
• Dér arrière: Shimano Deore
• Shifters : Shimano Alivio Trigger
• Cassette: Shimano 8 speed 11.32
• Selle: XTX 4 cross
• Potence: XTX Alloy ext 60mm
• Tige de selle: XTX Alloy
• Cintre: XTX Rise 30 mm Alloy
• Pneus: Maxxis High Roller 26*2.35
• Jantes: Aluminium Double Wall. CNC side with eyelets
• Moyeux: Shimano M475 disc hub
Le specialized Hardrock: dans les 500€
•FRAME A1 Premium Aluminum, double-butted, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger, disc only
•REAR SHOCK N/A
•FORK SR Suntour SF7-XCM-HLO, 100mm, 12": 80mm, 30mm Hi-Ten stanchions and steerer, coil spring mcu w/ preload adj., hydraulic LO, spring assisted seals, custom paint/graphics, disc only
•HEADSET 1 1/8" threadless
•STEM Specialized 3D forged alloy, two bolt, 31.8mm, 10 degree rise
•HANDLEBARS Specialized alloy 31.8mm, Enduro rise, 640mm wide, 8 degree back, 8 degree up sweep
•TAPE/GRIPS Specialized Enduro, dual density Kraton
•FRONT BRAKE Avid BB-5, mechanical disc, 6" G2 Clean Sweep rotor
•REAR BRAKE Avid BB-5, mechanical disc, 6" G2 Clean Sweep rotor
•BRAKE LEVERS Avid FR-5
•FRONT DERAILLEUR Shimano Altus FD-M310-6, top swing, 34.9mm clamp
•REAR DERAILLEUR Shimano Alivio RD-M410
•SHIFT LEVERS Shimano Acera SL-MC40
•CASSETTE FREEWHEEL SRAM PG-830, 8-speed, 11-32t
•CHAIN KMC X8, 1/2" x 3/32" w/ reusable Missing Link
•CRANKSET Shimano FC-M341-8, replaceable rings, Octalink Spline
•CHAINRINGS 42S/32S/22S
•BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 126mm for 50mm chainline
•PEDALS Specialized alloy platform, 9/16"
•RIMS Specialized/Alex HRD 26, double wall disc w/ eyelets
•FRONT HUB Specialized Hi Lo disc, 32h, CNC flange and disc mount, polished races, alloy QR
•REAR HUB Specialized Hi Lo disc, cassette, 32h, CNC flanges and disc mount, polished races, alloy QR
•SPOKES 1.8mm (15g) stainless
•FRONT TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
•REAR TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
•TUBES Specialized schraeder valve
•SADDLE Specialized Aggro, kevlar sides, front and rear bumpers, 143mm width
•SEAT POST Specialized alloy two bolt micro adjust head, 30.9mm
•SEAT BINDER Specialized alloy w/ QR
Salut et bienvenue.
Ta question est incomplète: ce nouveau vélo, c’est pour faire quoi?
Si c’est pour faire le casse cou sur des bosses, le viper me parait etre un bon choix: vélo typé “dirt” donc robuste mais en revanche lourd a emmener en rando.
Pour remplacer le 5.3,sur des rando sportives le spé me parait plus indiqué.
merci,
enfaite je pensait alterner les bosse et le cross country. mais je préfére le style des dirt. Donc si vous pouvez me proposer un velo qui correspond assez ça serait cool. (enfin je sait pas si un dirt pour le xc c’est possible :slight_smile:?!?! )
